User Tag List
Results 1 to 5 of 5
Thread: good one today
  1. #1
    Join Date
    Dec 2003
    Posts
    23
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    good one today
    I recived a call from a customer today who lived in a trailer park. Said head wont work lights are dim and go off sometimes then come back on.i read aboud 50 volts on one of the legs.when i showed up lights were going nutts and off for a min then on. first i thought neut. they have 4 meters on each line coming in. neut was ok and no one else was having a problem. as i started tracing the wire underground which was able to be seen in some parts i found a disconnect under a tree tested my voltage everything was ok. as i was reaching around checking the disconnect. i felt something burn my leg behind me. to make a long story short. someone broke the line coming in. spliced it back togeather with a romex connector. and cut a piece of garden hose to protect it. the hose was melting all the way up undernieth the trailer. i'm glad i got there when i did.and the wire was laying on the ground with a rock on it. i dont think it would have lasted another day without fire. so i shut it down replaced the wires underground in pvc. then twards the end i found out who did the splice. which was the guy who runs the park. i contacted ahj they want to come check out this park
  2. #2
    Join Date
    Feb 2003
    Bremerton, Washington
    Posts
    8,197
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Re: good one today
    Was that a UL listed hose?
    Moderator-Washington State
    Ancora Imparo
  3. #3
    Join Date
    Dec 2003
    Posts
    23
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Re: good one today
    the other half of the hose was still connected to the spicket... not even a good hose. one of them 2 dollar jobs
  4. #4
    Join Date
    Feb 2003
    Portage, Indiana NEC: 2008
    Posts
    9,911
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Re: good one today
    JP.
    Here in Indiana only HUD has the authority to inspect trailer parks. Something to check into.
    Wayne A. From: N.W.Indiana
    Be Fair, Be Safe
    Just don't be fairly safe
  5. #5
    Join Date
    Feb 2003
    Indianapolis
    Posts
    6,102
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Re: good one today
    Wayne, I don't know by what authority they acted but Health and Hospital forced some of the worst trailer . . . UH . . . mobile home parks in the Indianapolis area to update their facilities and run 4 wire feeders in some cases.
    Charlie Eldridge, Indianapolis, Utility Power Guy
    Responses based on the 2011 NEC, unless stated otherwise.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
