User Tag List
Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
Thread: stray voltage
  1. #11
    Join Date
    Oct 2003
    Posts
    3
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Re: stray voltage
    Just an update, I was finally able to prove the bonding was not attached to all points of the pool. Thanks for all your help
  2. #12
    Join Date
    May 2003
    Leesburg, VA
    Posts
    7,108
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Re: stray voltage
    Thank You for the Update........
    Brian John
    Leesburg, VA
  3. #13
    Join Date
    Apr 2003
    Westchester County, New York
    Posts
    3,552
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Re: stray voltage
    Take a blank piece of paper. Draw a pool in the center of the paper, then draw the parts, such as a ladder, diving board, fence, etc... Now draw a line between all of the parts (the line represents the bond wire), this will connect all of the parts and make them of equal potential.
    Stray voltage can come from a neighbor's property, the utility, maybe a lightning storm miles away. As the stray voltage passes through your pool area, it may raise the voltage level of the area. As long as the equipotential plane is properly installed, the raised potential will not affect people in the pool area, as like the bird on a line there will be no potential difference in the pool area that can cause problems.
    Pierre
Posting Permissions
  • You may not post replies
  • You may not edit your posts
