can 480 volt wire for temps be run in free air
S SEO Senior Member Location Michigan Oct 23, 2009 #2 If you mean temporary hook-ups look at section 225.6 (A). Installed in a code complient manner and use proper material per NEC it's ok. However you may have local codes to follow. Also look at Article 590.
