Disconnect
yordanys
New Jersey
Good Evening Guys,
Appliances for pools as a circulator water pump and Water heater required fusible or unfusible disconnect? Thank you in advance for your comments.
There has to be a means of disconnect for all pool equipment per the NEC. The equipment mfg should list in the spec sheet/instructions as to what they require.
