Cjmccarthy
- Florida
- Project Coordinator FDOT
This is an FDOT project involving a controller cabinet housing all equipment, including a ground array bonded to the power source ground rod. A concrete CCTV pole is located approximately 200 feet away, equipped with an aerial lightning protection system (LPS) connected to its own ground array.
Given that the only connection between the cabinet and the CCTV pole is a POE Cat6 cable, we would like to confirm whether it is necessary to bond the CCTV pole's ground array to the cabinet’s ground array, despite the distance or should it be isolated?
Your guidance on whether bonding is required in this configuration would be appreciated.
