Best soldering iron for tape light
Washington
Journeyman 02
Gettin a new solder iron for tape light connections, haven’t done this much in the past always used the lousy connectors which I want to avoid. Any advice on what to get ? Something simple and works good with tape light. Thanks
I'm a fan of the Milwaukee m12 soldering iron. I don't remember what I used for flux, but I would tin the wire, tin the soldering iron tip, dunk it in flux to clean the junk off, and put a dollop of solder on the tape, then heat up the tape with the wire touching. They would melt quick and bond nicely. Then I would clean all the flux off with CRC QD electronics cleaner.
The battery-operated is a good idea. My use of a corded iron goes way back. I’m old!
Awesome that’s what I’ve been Looking at. I did a lot of soldering when I started but it’s been about 10 years I haven’t done it hardly at all. Any good YouTube videos or advice you’d give for tape light solder ? Or just low volt in general I mean that’s pretty much all I’d be soldering
Tape light solder?? :rolleyes:
If you are familiar with electronic soldering this will be no different. ALWAYS use rosin core solder and if you have trouble getting the connection to "take" then clean it up and apply a little flux. NEVER USE A PLUMBING FLUX OR SOLDER!! I recommend Kester rosin core 60/40 (tin/lead) in .062" diameter solder and MG Chemicals - 8341-10ML 8341 No Clean Flux Paste,
As for an iron, 30W with a fine tip is fine. It's important to keep the tip clean and tinned.
https://www.amazon.com/Kester-Solder24-6040-0061-Solder-190ðC-453-592G/dp/B00DE3GG8K/ref=asc_df_B00DE3GG8K?tag=bingshoppinga-20&linkCode=df0&hvadid=80333160033505&hvnetw=o&hvqmt=e&hvbmt=be&hvdev=c&hvlocint=&hvlocphy=&hvtargid=pla-4583932708315091&psc=1
https://www.amazon.com/MG-Chemicals...&hvlocphy=&hvtargid=pla-4583863980022154&th=1
-Hal
I’m happy using a Weller 30W pencil-type iron on all types of circuit boards, including LED tape. You want a fine tip.
Used a Weller think it was a 25 watt soldering pencil type soldering iron to solder 15 or 16 printed circuit boards on a 25" Heathkit color TV years ago. Also still have the Weller 100/140 watt soldering gun my electrician dad purchased for me while in Vo Tech class. Weller makes a nice product. Always liked to have a wet sponge to clean soldering tips. Great improvement when they came out with coated soldering gun tips. My 100/140 Weller soldering gun has a copper element that should be cleaned then tinned before each use.I also liked using rosin core solder. Think 63% tin & 37% lead had the lowest melting point. Not sure of melting point for lead free solder.
-Hal
I will add to this. For the record, the eutectic alloy for tine lead solder is 63/37, but 60/40 is close enough that it works. Clean is the important thing, as hbliss pointe out. But also CLEAN is important. Add to that clean everything. I probably made my point. But I am talking, wipe off the solder itself with alcohol or Tri Clor. DON'T straighten it out with your finger, just the oil from that can affect a solder joint. Also don't use too much solder, you should be able to see the contour of everything you are soldering together including the stranding on the wire.
Soldering is an art. Anybody can do it, but it takes years to learn how to do it right.
-Hal
Yeah, I worked on Nuclear Submarines for a few years. Got qualified for nuclear soldering including mini pin connector plugs. First thing I do with every guitar I have owned is tear it apart and resolder all joints.
I have a cheap iron, probably Weller. It's got a larger tip, definitely not fine. I don't keep it clean, I don't tin it.
The right flux and solder are most important. And clean pads on the strip light. A very fine sandpaper is good, but I usually use the tip of my utility knife and gently scrape the pads.
I don't agree with a single point you made. A large tip can transfer too much heat too fast and cause the traces to separate and burn the insulation on the wire. The right solder and flux is a given but only in that electrical solder is electrical solder. Sandpaper is not a good way to "clean" the pads since it can leave grit. If you actually have green verdigis or build up a wire brush and some alcohol or degreaser. That part I may be making an assumption about is that you think when we say clean we mean bright and shiny, which isn't it. It is free of debris certainly , but mostly it is clean and free of oils and contaminates. Flux will take care of silver oxide or dull copper.
the single item that most helped me when soldering tape light was to use a soldering station with adjustable clamp arms and a magnifying glass.
