Hello All;
I have a question related to NEC 225.31 and .32:
At a Compressor Station, We have an Electrical Building fed from the load side of a Transfer Switch. The Transfer Switch is fed from the secondary of a Transformer. The Transformer and the Transfer Sw are mounted close by (approx 30' apart). The distance between the Electrical Building and the Transformer/Transfer Switch is approx 300'. The Service Disconnect Switch is installed on the Primary of the Transformer.
If we have a Disconnect Switch on the supply side of the Transfer Switch. Would that Disconnect Switch also qualify as a Disconnecting means for the conductors entering the Electrical building (on the Load side of the Transfer Switch) (applying NEC 225.32 Exception 1) ? We do have documented Procedures and LOTO for Isolating equipment in the station.
Your comments would be appreciated. Thank You.
