Does the 120v power for a gas, tankless water heater that is mounted in the exterior wall of a residence, and is accessed only from the exterior, and is cord and plug connected inside the water heater cabinet, need to be GFCI protected?
Did you put a cord on it or did it come that way. Mostly just curious because all the ones I have done are direct wired.
OP is doing gas and yes they are cord connected.
You can always use X-10 appliance modules for that. You could do a house-wide reset with a single button.After a power outage, the brain gets scrambled and you have to unplug it and plug it back in like a lot of electronics these days.
if this was hardwired, would it require a disconnect?
Cavie said:After a power outage, the brain gets scrambled and you have to unplug it and plug it back in like a lot of electronics these days.
Yes Disc or lockout on breaker.
Of course what kind of person puts a water heater outside, it will just freeze up.![]()
Southerners. :smile: We see it here occassionally but I have never seen one come with a cord and plug.
Either one could just as easily serve as a brain reset no cord needed :smile:
