Hi all,
I restored my Father-In-Laws house after it got flooded with 6" of water. Work was to remove and replace all flooring, woodwork and kitchen cabinets.
The city required that if the kitchen wall were opened up, that the electrical circuits would have to be brought up to Code...Minimum number of circuits and GFCI's.
I got an electrical contractor who gave me a price and he obtained the electrical permit for the work.
When the city electrical inspector came to do the rough-in inspection he said I needed to replace the Service Panel.
The Service Panel was a 60A, 240V with cartridge fuse main and screw base branch circuits.
10 Years prior central air was added to this house. Electric Service for this 30A MAX Overcurrent Protection A/C unit was obtained by connecting #8 wire to the line side of the Service Panel Main, and going to a 30A 2P disconnect mounted right next to the Service Panel.
The Electrical Inspector Said that it was not obvious that there was a 2nd disconnect to Totally disconnect power to the house and therefore failed my inspection.
I screw attached a Sign on the front of the Service Panel and the A/C disconnect (Phenolic, with 3" high letters) saying there were two disconnects to completely disconnect power to the house, Service Main and A/C Disconnect Switch.
Electrical Inspector would not pass the service, and I had to replace the service.
I don't think he had anything to stand on, and all was within Code. There were no electrical loading problem (all appliances are gas and heat is gas).
I think he had a problem with the A/C branch circuit being connected under the lugs with the main service drop feeder, but they fit just fine, and there was no sign of overheating.
Should I have fought this one, or was there a code violation somewhere?
