Supports
In most instances you would use them in a box or in a piece of equipment unless your conductors were somehow run in free air.
I was really referring to vertical runs in shafts etc. Thanks.
Well if you're running conduit in the shaft then you would use those cable support bushings in a box every XX number of feet depending on the size and type of conductors.
