Nathan Daniels
- Portland, OR
- Electrician
This question is part code, part engineering. With current sinking (architectural) 0-10 volt dimming, what are the hazards and/or potential code violations of running the dimming circuit to fixtures running on different circuits.....potentially even from different line voltage sources?
Most commercial LED fixtures we install these days use universal drivers that run off 120/277 volt power. They produce a voltage which is then sent in parallel along with any other fixtures on the same dimming circuit to the dimmer, which uses variable resistors or PWM to drop the voltage, which tells the driver what percentage to dim. The drivers are designed to read the resistance/voltage drop across the dimmer without respect to the other fixtures that may be on the circuit. I've seen areas of open offices that have some 2x4 lighting on normal power mixed with other fixtures on emergency power, all sharing the same dimming circuit (using emergency relays to bypass dimming when normal power power drops out). This seems to work, but I'm not sure it's okay.
I'm guessing there may be a code issue here but I haven't been able to find one. I've also searched the literature online and I haven't been able to find anything from an engineering standpoint that says this is no bueno. Anybody here have any knowledge about the subject?
