A dimmer with 0-10VDC control of dimming:
1. Would the dimming wires (grey and violet) (running with the circuit wires) just daisy chain form driver to driver along the circuit?
2. Do I need to worry about distance? (or is the control amps so low that it is not a factor?)
Correct me if I am wrong - The wires can be run together if the control has the same insulation.
Is 18 usually used (I would have thought 14)?
Would you run them in the same conduit out to the fixtures?
