kyleapec
- siloam springs arkansas
They have designed the MRI room with the 0-10v Dimming Switch inside the room, will the magnetics mess with the 0-10v dimmer switch?
Thank you, I will write up an RFI, but I wanted to do some research first. The only other MRI I have done, the switch was outside the room. Everything will be shielded with the exception of the switch itself in the wall with a regular cover plate. Would you be worried about the interference of switch itself if everything else is shielded?
I really don't think this is something you need to concern yourself with, not your job. MRI rooms are designed by the manufacturer of the machine and if they indicate a dimmer on the inside wall I wouldn't question it. They know way better than any of us do.
-Hal
