Thanks for all the responses on my last post.
My other problem I ran into with the inspection, is the LED recessed lights I'm dimming. The driver has a grey and purple lead that hook up to the Lutron 0-10v dimmer. The inspector is making me take the wire out of the switch box, saying it has to curl around the box and into the switch box. I kno LV and 120v isn't suppose to be in the same box, but It's made up in the recessed can splice box together, and it's tieing into the back of the dimmer leads in the switch box. What's the code on this? The sheet rocker will probably cut all those wires this way.
