Can I run in the same raceway the 0-10volt dimming conductors and the 120volt power conductors for lighting if I use conductors that have the same insulation ratings?
Only if the lighting control system allows you to reclassify their Class 2 system as Class 1 limited power and you use Chapter 3 wiring methods.
See 725.130 (A) [2014]
The reclassification can only be made if the signal processing circuitry in the luminaires does not require a Class 2 power supply for safety.
Look in detail at the manufacturer's literature.
Parts of the control circuit which do not share the raceway with power circuits will still be prohibited from using Class 2 wiring methods and rules.
In which case you still need to find out whether the dimmer connections are protected against harm from external voltages or need the protection of Class 2 wiring with isolation from other circuits.? ? ?
The dimmer is bus powered. The current is sourced from the BALLAST.
Equipment which can be reclassified will state that if can use either Class 2 or Class 2 wiring, or similar wording.
