inspector23
- Temecula, CA
2008 NEC 690.8(B)(2)
I am hoping for some insight for this section. For whatever reason, this section makes absolutely no sense to me. I am not sure if it is a senior moment, a blind spot in my code vision, or the result of a Death Star collapsing in another Galaxy, but I cannot fathom:
the intent;
the meaning;
or for that matter, I cannot comprehend what the 125% has to do with anything, because I do not understand anything about this section.
I cannot even tell you why it is located in this section!
If the modules have the ability to internally limit the current are permitted to be rated less than the 125% addition required by 690.8(B)(1), than how can the reduced rating shall be at least 125% of the limited current value.
I have tried ROP?s and ROC?s, I am a member of NEC Plus and I tried there with no luck, and the 2008 NEC handbook did not enlighten me. Before I am committed to a rubber room, I would appreciate any/all help with explaining this code requirement.
I hope I said that well. Thanks in advance for your help!
Mike
the intent;
the meaning;
Mike
