Hello to all! Installed 2 bronze ground clamps on an old 1-1/4 inch black pipe water line, Ground clamps are rated 1-1/4 through 2 inch. I couldn,t quite get it tight just by a hair. I put a piece of #4 solid in the cradle of clamp which worked to make it tight, but 1/2 of the clamp is not completely seated against clamp because of the #4. Though it is tight, I,m uncomfortable with the other 1/2 not being solidly seated against black pipe. Is there a special clamp for the old black iron water lines? or it may be 1-1/8 pipe. But the ground clamps were sized 1/2 inch to 1 inch or 1-1/4- through 2 inch. any advice greatly appreciated
