1/2 EMT with #6 x3 and #10 x1
tmg22
New User
North carolina
Self
I am running a 60amp outdoor subpanel less than 7ft off my main panel inside. There is currently an existing j box going from main panel to outside I’m going to utilize for this, but about 2 inches of it go thru 1/2” EMT conduit. I have 3 #6 THHN wires going thru it and 1 #10 ground also. It fits thru just fine. But according the conduit fill chart that’s not recommended. Is 1/2” EMT conduit a deal breaker for this amperage and number of #6 thhn? The only issue I could see is some sort of rule with the wires not having enough air around them to keep cool if at max amps but it’s only 2 to 3 inches.
Hot tub and shed are on this sub panel. will it ever pull 60amps. Maybe if both the hot tub jets and heater are both at full and the shed window AC unit is running plus operating table saw, etc. But that would be rare since the jets only run at full if someone’s in the tub
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the button at the bottom left corner of the post.
