1/2" ground rods
jeff48356
Since Code requires two 5/8" copper ground rods for each new service, why does the Home Depot even carry 1/2" ground rods? You'd be surprised at all non-Code compliant items that Home Depot sells. What are 1/2" rods used for if not for service grounding electrodes?
Are they listed and stamped? Reread 250.52(5)(b). Copper rods are never required.
Telco and cable grounding? Not that that's the proper way to do it, but still...
SceneryDriver
Never pulled one up to measure it.
i did see a bundle of short ones designated for a company that sells portable lighting systems, but nothing else that I remember.
When I did resi up grades I was taught to always assume that all grounding, electrical and telco, was inadequate unless verified.
I never verified crap, just supplemented with code legal options and left the other stuff as auxiliary and not subject to code mins.
I bought some LFMC at the supply house today, it was non-UL listed. They started selling a bunch of generic off-brand stuff lately. :roll:
The one at Lowes are 1/2" and are listed
Here is what the code states
Rod-type grounding electrodes of stainless steel and
copper or zinc coated steel shall be at least 15.87 mm (5∕8 in.) in
diameter, unless listed.
