Re: 1-200 amp meter base feeding 2- 200 amp panels
Hot sequence, lever bypass 200 amp socket, commercial building, 2/0 cu feeding the meter base and the two breaker panels (one inside and one outside), each having a 200 amp main. The conductors feeding the panel mains are doubled up under the meter base lugs.
