A
a.wayne3@verizon.net
Guest
We have gotten tagged for several panels this week having over 1/4 in set back on the panel.
on rough the rough in guy mounts the panel and sets green board on either side of the panel to the ceiling as a chase,then the drywallers cover and finish it by the time its done there is between 1/4 to 3/8 gap between panel face and the panel edge.So after getting tagged i had service go and remove the corner bead and drywall from the edge of 2x4.now the panel cover is flush.on recall the inspector again tags it this time with a note:have to see finished product and will not reinspect till its done !!!!! What does this have to do with the nec ????The builders are furious and so am I.I asked the inspector if we could use fire caulk on the exposed dry wall and no was the answer,he wont accept that,anyone run into this???
