1 Brkr- 2 Panels
Alwayslearningelec
NJ
Estimator
Per code can you have one breaker feed two panel boards?
Say a 400A MCB feed two 200A MCB panelboards? Obviously, if allowed, you would run a 400A feeder to a tap or splice box then feed each panel from there.
Or I guess you could run feeder from 400A MCB to panelboard and use a branch breaker in the panelboard to feed the other panel.??
Yes. Follow the 240.21 rules if conductor to individual panel is reduced
Yes
