I'm heading out to a job in the a.m to install a heater. I've only been in the building once before (replaced a coil for a starter), and I'm fairly certain the the service 120/240 4 wire delta. I was given the specs on the heater from the customer as 240v 1ph unit. Now, am I correct to believe (if this is in fact a high leg delta), that with a 2 pole breaker on any combination of phases I will get 240v? Sorry if this is too simple of a question, but these types of services aren't very common around here, so I do not have much experience with them.
