I need to connect 10/3 SO cord into a termination strip on a sauna controller.
The strip has set screw type compression terminations.
I noticed that the factory provided cable that comes with the unit heater that attaches to the load side of the strip has ends attached to the stranded wire allowing for a flat solid surface for set screw to seat against.
There are no specifications for the type of end required on the field wiring ( SO) cord I will be providing.
Would it be satisfactory to tightly twist the stranded conductor and place it under the set set screw type compression.
I cannot see what the make up is of the screw end ( pointed, flat, etc.) or what the inside of the termination cavity is. It’s a plastic body type strip and unable to be removed for any type of inspection.
The load is 24A @ 240v
Thanks
Thanks
