DARUSA
- New York City
I know it is not a code rule but usually for the 10 point meter wire what kind of conduit are you guys using ?.EMT or Rigid?
Huh???? My ignorance is showing. What is 10 point meter?
A ten point meter pan is used with a three phase service that has CT's. It's been a while but I believe that you can use either. And don't forget the 10 conductor, #9 AWG meter wire.
Their own spec for some things says EMT may be used, note D:
http://www.coned.com/es/specs/electric/Section%20XV%20-%20Spec%20195.pdf
Usually I use EMT conduit but a Con ed inspector requires me to use a rigid pipe.
I have been involved in at least 20 diferent buildings and we always use emt.
Now the reason for it is because he says some body can easily open a coupling and cut one of the wires and change or alter the meter reading .
The funny part is he says that I have to use rigid but I can use compression fittings . What is the difference ?
