10 volt dimming
stew
Been off the forum for a long while due to health issues. Back in the saddle again.
Just did a large retrofit of 30 year old troffers.120 units.
The technology has ran past this old fart. Does anyone know of an inexpensive way to dim these buggers. The normal way of course woukd be a driver on the first fixture of 6 in a room and low voltage wiring. With a retro and Mc feeds to all the switches it's a bugger. Any ideas besides 175 $ worth of parts? No real way to feed the low voltage. No emt. .only eat is the feed to the first j box in the array.
Dimmable linear LED retrofit lamps are available, for use with compatible dimmer switches.
If the project is under the jurisdiction of Washington State energy code, you may need an EMS, with daylight harvesting. More expensive devices.
