100 amp fuse in 200 amp panel
JJWalecka
New England
I have FRS-R 100 AMP fuses to be installed in a 200 amp disconnect. Could someone tell me what the fuse adapter is called? Possibly a part number or point me in the right direction
Thanks
Think its a Bussmann 2621 but you might want ton check their catalog
There is also at least one fuse manufacturer that makes smaller rated fuses in a larger body to avoid a separate fuse reducer accessory and the potential UL listing issue. I know Mersen has Class J and RK1 fuses available, but I don't know if they go down to 100A.
