Have a project that requires 100% neutrals, and nothing less than 3/4 emt, this is making the lay out of home run pipes an issue if each neutral is counted for conduit fill.
I understand a balanced load of a full boat, 3 phases, and a neutral, which means the no load on the neutral and not counting it in the pipe fill.
This said the 100% neutral is just three times the conductor area, for the same unbalanced load. So I assume they would not count in the pipe fill.
Still keeping with 9 conductors per pipe!
