I've seen a number of One-Line drawings lately that indicte the use of 100% rated breakers for particular breakers.
Can someone explain the resaon behind specifying or using 100% rated breakers in a design.
I believe I read an article some time back that explained that a sysmes installation cost could be cheaper using 100% rated breakers becuase you did not have to de-rate cables and thus could use smaller cables and reduce the installation cost of the system. Is this typically why 100% rated breakers are used?
