I am using right now:
Dryer - 3,000W
A/C or heating- 3,000W (minimum)
Oven - 5,000W
Broiler - 3,000W
Water Heater - 3,000W
Fridge/dishwasher/tabletop top/broiler/lights/microwave/etc - up to 4500W
Other appliances (hair dryer/PC/etc) - not in use when I work
I have recently started a small cooking business. COVID and all. I am afraid I am overloading my circuit.
I have a 100A 120/240 panel, typical here. This should imply I have 24,000W of panel. I have balanced my 120V appliances between the two legs on my panel.
According to my calculation, my max power draw, if everything runs at once, is 21,500W, which is way below the 24,000W limit. I should be fine, right? I also overestimated some W, oven very rarely pulls 5,000W (and waster heater isn't always on)
My issue is - I took at look at the main breaker, aka the one in the basement of the building, and it has a big "100A" on it. Is this because it brings 100A at 240V to me (24000W total)? Or do I have only have "100A 120V"=12,000W in my unit?
In other words, the main breaker, in the electrical room of our condo - does it bring up 100A of 240A to me? Can I fully use 24,000W of appliance power (or 80% of that anyway)? I use dedicated lines for each appliance.
I know this doesn't sound ideal but that's all I have. I am afraid to start a fire or cause problems. I use the oven A LOT and same for other appliances.
OFC I am not using them full time, but according to my electricity provider, I am using around 370KWh a day (!!!!). Obviously not using the appliances at night much (some of them however).
Thank you.
Dryer - 3,000W
Oven - 5,000W
Broiler - 3,000W
Thank you.
