mattlikesbikes
New member
- houston TX
Hi,
I am hoping y'all can help me figure out a he said/he said issue. I am having a heat pump installed at my house and when I picked the unit the AC guy told me to tell the electrician to wire for a 10kw system. The electrician goes ahead and runs a #8 line. The unit shows up and is stamped that it needs 60amps, which is a #6 line. AC guy says they have not seen a 50amp 10kw system in a long time. Electrician says that a 60 amp system is a 15kw system in secret.
I'm an engineer and know enough about electricity to hire a professional, but when I look at the NEC guidance and the tables I have trouble figuring out where my professional came up with only running a #8 for a 10kw system. When I do the math I get 52.5 amps without the blower (10,000/240 *125% = 52.5). Already the peak is above 50 amps and you don't have 2-4 amps for a blower, which clearly kick you to a 60 amp #6. At the very least isn't the continuous load on a 10kw system over 80% of 50 amps (42 amps) and thus by NEC you have to go up to 60 amp?
Ultimately I think that my electrician is just using old and maybe fuzzy math. He is running the #6 as we speak, but I've got to figure out if this is an electrician I want doing my next remodel (we just did floor 1 of our 2 story duplex), want to recommend, etc.
