- Bremerton, Washington
- Master Electrician
2011 NEC 110.14 add the requirement for fine stranded conductors to use connectors and terminals identified for the specific conductor class.
Has anyone seen an issue with fine stranded conductors being damaged from using an the incorrect connector/lug?
I have a compression terminal kit from Burndy, it has lugs for fine stranded conductors and the barrel opening is slightly larger than for a class B or C stranding conductor.
Perhaps the damage would come from a set screw lug?
