Added:
FPN: Checking for presence of voltage prior to working on unenergized equipment would not be considered examination of energized equipment.
I've seen several submittals over several cycles try to clarify this paragraph. A lot of it seems to stem from the handbood's explanation that checking voltage is an examination and requires a working space. Inspectors have used this to require items like non-fused disconnects to need a working space. Since every text change has been dismissed by the Code-Making Panel I thought they might be more agreeable to a very limited scope fine print note.
