greenjeans
Inactive, Email Never Verified
- Now living in Virgina
Having a problem with a steamer/jazz shower /tub /lights/ h20 pumps. This contraption only has an international listing (which means nothing to me)
The electrical requirments for this is as follows: AC 110 60HZ water voltage 0.1-0.2Mpa (HAVE NO IDEA HOW TO TEST THIS AND WHAT IS mpa?), steam generator 4K, water pump 0.9K, heat pump 1K, air pump 0.2K. This is ALL 110 volts. Under the tub, ther are two cables- one for the steamer and one for the everything esle(pump,heater and h20 pump) I have a 6/3 feeder over to the tub disconnect panel, can i install a 50 amp two pole GFCIB to feed the disconnect and then use 50 amp single pole breaker for the disconnect for the steamer(110Volts) and a 20amp for the jazz pump and heater disconnect(110 volt). I have found no UL or ETL or CL listing on this tub/ streamer/jazz unit. Should I be hooking this thing up at all. has any one come across this THING before, thanks for your input.
