ptonsparky
Tom
- EC - retired
Customer called and wanted a private line locate done. Ok. Not. They had the transformer open for me. Ah, no thank you. Most likely I will let some one else do it unless I can find a local with experience and safety gear. Mine is.not rated for that.
My older Ideal locator has an antenna that will induce a.signal into a cable if it sits above the buried cable. Has anyone else use this method of locate successfully? I don't use it (that method) because you can not guarantee what you may be finding.
