Sangha Energy
- United States
Hi, I'm new to the forum but thought this might need engineering or calculations to represent.
Recently I fixed a medium sized generator - 100kw three phase. The 12 lead generator head had been rewired from 480 three phase to 208 three phase plus some other engine repairs had been done. So I assumed that all 12 lead generators run at 1800rpm. I timed the engine with a timing light to run at 1800rpm. Output voltage was like 95 per leg, so I thrashed around trying to adjust the voltage regulator to bring the voltage up. Finally getting the exciter circuit breaker to start shutting down DC current to the exciter.
Went back to the drawing board and checked frequency - 37hz! So I adjusted the governor up to 60hz, bingo output come up to spec, exciter current dropped - all happy except the customer because his big block chevy was running at 3900rpm, I told him 3600 but he complained that his tach said 3900. Bottom line - customer is not happy his generator while working and making good power runs at 3600rpm. With a big block chevy pushing the generator head the fuel costs would be very high.
So, sorry for the long story - can someone explain how a 12 lead generator head runs at 3600rpm and not 1800? Any chance the rewiring was done incorrectly? Can anyone point me to the engineering/physics of 12 lead generator heads and RPM? I know all the output wiring options what I want to understand is the relationship of winding/leads/rpm.
Thanks,
Thanks,
