Solid, 7 strands, then 19 strands. Table 8 has normal conductor properties, there can be other configurations. This is from the UL White Book (in my opinion, the rest of your code book),
WIRE CONNECTORS AND SOLDERING LUGS (ZMVV)
Wire stranding ? Unless clearly marked ??Solid,?? ??SOL,?? ??Stranded?? or ??STR?? for a given wire size, wire range or wire combination, conductors in the range 30-10 AWG are both solid and stranded, and 8 AWG and larger
are for stranded wire only. Connectors additionally rated for metric conductor sizes are marked with the letter ??r?? for rigid solid and rigid stranded conductors, or the letter ??f?? for flexible conductors.
Stranded conductor Class ? Connectors rated for use with stranded conductors are for the following strand configurations:
- Aluminum ? Class B concentric, compressed, and unidirectional lay
compact
- Copper ? Class B concentric, Class B compressed, Class C concentric
Wire connectors additionally rated for use with compact copper conductors are additionally marked ??For compact-stranded copper conductors?? or equivalent on the connector, or on or within the unit container.
Wire connectors additionally rated for use with other Class conductors,
such as Class M, are marked with the additional class designation and number of strands.
