12 volt distribution system for house.
Coppersmith
Tampa, FL, USA
Electrical Contractor
If you were going to have a battery system with your PV array, would it make sense to have a 12 volt distribution system in the house to avoid inverter losses? At minimum, lighting at 12 volts would be easy and comparable in quality to 120v lighting especially if LED. It works well in RVs.
kwired
Electron manager
NE Nebraska
I would think depends on load(s). VD is a bigger problem with only 12 volts. Supplying lights only, you may get away with it easier though.
ggunn
Austin, TX, USA
Electrical Engineer - Photovoltaic Systems
Most battery based inverters do not operate at 12V; most of the older ones are 24V or 48V and some of the newer ones operate at much higher DC voltages. On a 24V or 48V inverter you could theoretically tap into a battery chain and get 12V, but at least with lead acid cells this would be a very bad idea. It is important for battery longevity that they all get the same charging and discharging treatment.
In any case, inversion losses are pretty small. IMO it isn't worth doing.
DrSparks
The Everlasting Know-it-all!
Madison, WI, USA
Master Electrician and General Contractor
The important thing is to size your inverter properly. Oversizing will result in less efficiency. Look at efficiency curves for inverters that you're interested in. You will note that they approach their optimal loading.
You could do a 12 volt system for lighting and use LED modules. You would experience the most power savings there.
Sent from my A574BL using Tapatalk
DrSparks
Madison, WI, USA
I don't know how to edit on the app. I meant to say the efficiency approaches 100% at optimal loading.
jaggedben
Northern California
... It works well in RVs.
And whether your desired loads are limited to quality
products readily available for the RV market would be an important factor.
I think it might make sense for a system that will no connection to the grid whatsoever. Almost certainly not otherwise.
There are a few things I would likely run dedicated 12 volt lines for: refrigerator, freezer, circulator pumps.... But except for maybe the smallest systems, I wouldnt run lights at 12V anymore. There is a great little 300 watt inverter, the morningstar suresine, which has super low idle and standby current. Your typical larger inverter is actually pretty harsh on idle and standby losses. I would entertain the idea of using the suresine for lighting and general use outlets, and using a big inverter only for things that really need it.
Adamjamma
There are 24 volt lights, including light bulbs that can be used in your old lighting fixtures, as well as 12 volt lights. However, there are as yet no cieling fans with lights in either voltage but you can buy cieling fans in 12 volt, and wall fans in both voltages, along with refrigerators, freezers and even one washer so far in 12 volt.
petersonra
Northern illinois
engineer
I think that overall it is a bad idea. it limits the homeowner to using either landscape or RV lights in their home, for the most part anyway. Inverters are available these days with very low losses. As others have mentioned there are not all that many serious PV systems running 12VDC anymore anyway.
OTOH, if the HO wants to pay you to do this after you have explained in writing that it is a bad idea, feel free to go ahead and do it. It will just mean someone else will have to fix it when they sell and the new HO finds out the mess that was left.
You can run 12 V for appliances but most of them do not get used enough that the HO will ever see any return on it. Buy very high efficiency 120V appliances instead.
Adamjamma
Yes. Lower volts, higher currents. Possibly/probably larger conductors for some things.
Our electric kettle is 3kW...........at 12V................'nuff said.
Well, check with the truckers. I have used a portable kettle in my ford transit and my Nissan Frontier with no problem, but, the 24 volt version does heat up faster. Also, if you check in certain areas, there are a load of 12 and 24 volt gear that is not RV style... I can buy bulbs in Jamaica in either 12 or 24 volt, that fit in ES or BC or even mini BC fittings,and also full size fans and ceiling fans. Certain companies in the USA sell full size freezers, and I have seen them used in the USA and Jamaica with a group of solar panels wired through a charge controller to a small bank of deep cells, and wired to the freezer. Same with Fridge units...
but these things do not fit in your RV, and are more costly than AC units so it is a trade off. However, I understand even the Amish are starting to use the solar panels direct to such items.
