When you have a single phase service drop as part of a 3 phase 120/240 high leg service arrangement
Yes, 600 amp ct service with a 200 amp 3 phase riser and a 400 amp single phase riser
Let the POCO know how your load is changing. Is the existing 3 phase service large enough to handle this load or are you adding another 3 Ph service disconnect?So one more questions, I need to add another 200 amp 3 phase disconnect to this same drop. I have 3 phase rooftop and then the rest will be single phase load. Do I do a separate calculations for the three phase and single phase loads. Single phase loads our for a cafe equipment
Adding a additional 3 phase 200 amp disco to handle the new 3 phase load and the new single phase loadLet the POCO know how your load is changing. Is the existing 3 phase service large enough to handle this load or are you adding another 3 Ph service disconnect?
