120/240 single phase troubleshooting.
montericci
Ottawa, IL
Hello all,
I should know but am not sure of the fix for a singe phase problem I've encountered.
My daughters recently purchased clothes dryer would not work in her mobile home. I hit the start button and recieved a buzz but the dryer would not start.
I checked the breaker panel (mobile home specifice) and discovered that there was no ground coming into the enclosure. Only 2 hots and a neutral. The box has a neutral bus and a ground bus and her loads were installed correctly as best I could tell. However with no ground I suspect the 240V load must not have a good reference. I turned off the 30A breaker, removed the outlet cover and replugged in the dryer with the cover off. I had previously checked the voltages at the outlet and my meter read 246V accross the two hots.
I turned the breaker back on and carefully measured the voltage from each hot to neutral while she held in the start button. On the first hot - to - neutral I read 125V, on the second I read 36V. I turned the breaker off and connected a jumper from the neutral bus to the ground bus in the panel to obtain a common reference and tried the dryer again (this time with the outlet cover back in place). The dryer started but would not heat up. I know the dryer works as I tested it just prior to purchasing it. What is the trouble and how do I fix it.
Thanks, Monte
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
