in a 120 circuit does touching the bare grounded neutral give a shock
That depends. Are you grounded? Is the neutral connected as it should be? For instance if a circuit has a few receptacles that are daisy chained with a load at the last receptacle and you disconnect the receptacle neutral in the middle you will complete the circuit through your body if you touch both daisy chained neutrals. Touching one neutral and a ground will also give you a shock. Touching any one wire and being totally insulated will not shock you--- like a bird on a wire.in a 120 circuit does touching the bare grounded neutral give a shock
The neutral carries current. If everything is working all the voltage on any neutral will be at ground potential.when touching the neutral that another path for neutral current to ground and should have current regardless how proper system wired right?
