spotted123
- South Texas
We have 2 panels fed by the above service, 1 three pole breaker feeds the sub-panel, and 2 pole breakers feed Control cabinets of various duties. This equipment is on a marine vessel that is sensitive to grounding issues (Tanker). I have not been able to access the actual equip. but am trying to understand the engineering behind this type of service. Usually electronic equipment is very sensitive to "floating" neutrals but in this case the 2 wire 120 volt supply may serve to reduce that problem? Maybe there are power conditioners in the panels? I will attach the edited drawings to be clear.
