The plans call for480/278, 200 amp main meter can then that feeds a 200 fused disconnect, the fused disconnect is labeled pv disconnect. From that disconnect it feeds a
400 amp 480/277 subpanel with a backfeed breaker of 150 amps and 200 amp that feeds a 75k transformer for the low voltage loads, I’m thinking that I can only backfeed 40 amps of solar based on my main meter can and 200 amp disconnect. Bussing is only 200 amps on both meter can and fused disconnect
