Fordean
- New Jersey
- Electrical Contractor
What problems can this cause? conduit is underground. Told them we need to pull out the aluminum 8 - 250kcm and install new wires with ground. Can we dig a trench next to 4 inch and run a 1 inch and install a ground in it. So not to cut up 8-250's?Wow so all that 400A house panel had was the earth as a EGC?
You might check voltage drop under full load at a peak time the W/ POCO present, sometimes they can 'notch up' the transformer changer taps, that would drop the amps some.
