clombardi66
- Louisville, KY
- Maintenance Technician
It was supposed to be a simple job. Had a dead hand dryer, the job should not have taken more than 10 minutes. Had seen the breakers in a previous job, so I went out and flipped them. When I came back inside there was still 120V on the hand dryer. Nothing else was labeled as hand dryer, so I got out my circuit tracer. Got a few hits, but nothing was taking down power. Ran in circles looking for any panels I was not aware of, with no luck. I didn’t really see what happened, but somehow a jumper made contact between hot and ground on the hand dryer and tripped that breaker, so I thought at least we would be able to find the it now. Ran in circles and didn’t find anything, again. I had remembered seeing this store had a handful of circuit breaker locks and determined it had to be one of those. Checked every single lock and nothing was tripped. Finally went into a 480/277V load center and the first circuit breaker lock I removed was tripped. Sent a co-worker inside to confirm if this was our breaker, which it was. Only when that breaker was in the off position, it was still showing 19V. At that point I was so confused I went out and confirmed that the parking lot lighting that was fed from this panel was in fact @ 277V, which it was. After going back to the electrical room, I found a second panel schedule behind what was visible in the slot and somebody had hand written, “hand dryer?” in that exact breaker number. How is that possible? The only thing I can come up with was somebody made their day a heck of a lot easier by installing a step down transformer somewhere hidden, in place of tying that back to the correct breaker. 4 hours of running around for what should have been a 10 minute job.
