D D-Nice Member Jul 28, 2009 #1 I am only reading 60v coming out of a new halogen flood...is this right? Lights work fine, but shouldnt it be 120v?
Sierrasparky Senior Member Location USA Occupation Electrician ,contractor Jul 28, 2009 #2 D-Nice said: I am only reading 60v coming out of a new halogen flood...is this right? Lights work fine, but shouldnt it be 120v? Click to expand... Hi could you elaborate a bit more.
D D-Nice Member Jul 28, 2009 #3 When I remove the bulb and put a meter to the contacts it reads roughly 60 volts on each flood. I thought I should read 120 volts.
Sierrasparky Senior Member Location USA Occupation Electrician ,contractor Jul 28, 2009 #4 Is there a dimmer ?
Sierrasparky Senior Member Location USA Occupation Electrician ,contractor Jul 28, 2009 #6 Pardon me if I don't see the obvious. What does the voltage read at the outlet? If it's the same you have a missing nuetral.
masterinbama Senior Member Location Huntsville Alabama Jul 28, 2009 #7 Is this a quartz Halogen fixture, and are you using a digital meter. Some of the quartz floods have lamp contacts that disconnect from the source when you take the lamp out. You might be getting phantom voltage.
LarryFine Master Electrician Electric Contractor Richmond VA Location Henrico County, VA Occupation Electrical Contractor Jul 28, 2009 #8 Can you read the voltage with the lamp in place?
H hurk27 Senior Member Location Portage, Indiana NEC: 2008 Jul 28, 2009 #9 LarryFine said: Can you read the voltage with the lamp in place? Click to expand... Better have some long probes. then there things get hot and I mean HOT!
B broadgage Senior Member Location London, England Jul 29, 2009 #10 Or the light might be turned off, leakage accross switch contacts or accross a photocell or a presence sensor could give 60 volts on open circuit.
