120v Receptacle from 240v A/C feed
pierre
There is a 240 volt feed to a 20 amp A/C air handling unit (the A/C unit does not require a neutral). A 3 wire feed including, 2 hot conductors, 1 neutral conductor and an eqiupment ground conductor feeds the A/C unit.
Can a 120 volt receptacle be taken from the 240v circuit feeding the A/C unit, utilizing 1 of the hot conductors, the neutral conductor and the EGC? The 2 pole-20 amp breaker will be protecting both the airhandler, and the receptacle.
I know this is physically possible, is this permitted by the NEC?
Pierre
luke warmwater
Re: 120v Receptacle from 240v A/C feed
Cutler Hammer now makes an A/C disconnect that has a 125v. GFCI receptacle mounted in the bottom of the enclosure. It states on the unit that it Must be fed from a seperate 125v. circut. It cannot be tapped off of 1 of the legs of the 240v A/C line.
jim dungar
Wisconsin
PE (Retired) - Power Systems
luke,
I do not see any NEC restriction against tapping off any 20A branch circuit to feed an associated 20 receptacle.
The C-H restriction for integrated 15A GFI has to do with the probability of the AC system being feed with a breaker larger than 15A.
Warning possible thread hijack:
Manufacturers do not build equipment based solely on the NEC. NRTL do not test equipment for compliance with the NEC. The NEC is not a design manual. The current edition of the NEC is not, and has never been, a universally accepted standard or code. Also, it seems the NEC is driven more by manufacturer's designs than vice a versa.
[ August 26, 2003, 10:49 AM: Message edited by: jim dungar ]
websparky
Cleveland, Ohio
If the 2 pole 20A CB supplied the AC unit and it includes a neutral conductor, we would then have a multiwire circuit. No?
NEC 2002 210.4 Multiwire Branch Circuits.(C) Line-to-Neutral Loads. Multiwire branch circuits shall supply only line-to-neutral loads.
luke warmwater
210.63. The tap would not be allowed on the load side.
There would also have to be overcurrent protection for the receptacle.
Being that this is a 20 amp circut, if all of the associated tap rules were followed, then I guess it would be allowed.
But then again, this is an A/C circut. It might be protected by a 20amp cb, but what is the wire size that is feeding it??
It could possibly be 14awg. And that, I think would make it a different animal.
But, should this be included : 210.23(A)(1) and especially (2).
