MattS87
- Yakima, WA
I am installing a 120V to 24vdc power supply for some safety strobe lights. The line side with come from a receptacle circuit where the receptacle is 4' off the ground. The power supply will be mounted about 20-25' off the ground on a steel column. The lights are controlled via a s.p switch at ground level to alert forklift traffic of pedestrians. Does anyone see an issue with switching the 120V to the power supply to accomplish this vs. switching the 24V? I ask because running one conduit would much easier than 2 but not sure if it would adversely affect the p.s.
