SiddMartin
- PA
checkin out a remodel today and found 120v on the ground! Found the circuit causing the problem and this is what I believe is causing it: There is a short somewhere on the circuit and the ground is not connected to EGC causing it to "float" through the grounds that are tied together. What other possibilies are there? (I'm sure there is more).
I must say, it was crazy when I hooked up my voltmeter and saw 240 to ground! (Because Circuit A is 120v and the other 120v was coming from the ground "problem", they are on dif. phases.)
