GerryB
- woodbridge, ct. USA
I have never seen this before but in this apartment building which is a 3 story brick building with 30 units there are some 120 volt meters. They actually have only 200 amps overall coming in. Then it distributes to different areas like where I was working with a disconnect and a bank of 6 meters. Four of them were newer in their own meter socket, 240 volt. The other two were the old style meter above the fused disconnect, 120 volt. The neutral was also fused. Every thing comes off a trough. There is only 30 amps to each apartment, a four fuse box in each apartment, (and the feed to each apartment is 12-3 bx, don't know how they got away with that.). The job is to upgrade each apt to 60 amps and circuit breakers for the future (next summer) expansion or some basement apartments and service upgrade probably to 1200amps. My question is if I run the 60 amps to the current locations can I splice these in the future when the new service will probably have all the meters in one location?
